AOC Pro-line U3277FWQ 31.5" 3840x2160 4ms HDMI DVI Displ...
AOC Pro-line U3277FWQ 31.5" 3840x2160 4ms HDMI DVI DisplayPort VGA LED Monitor
Product codes
The AOC U3277FWQ helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals fine details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction, wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video.
AOC Pro-line U3277FWQ - LED monitor - 31.5"
LED-backlit LCD monitor - 31.5"
Panel Type
A-MVA
Aspect Ratio
16:9
Native Resolution
3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Brightness
350 cd/m²
Contrast Ratio
3000:1 / 80000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, MHL, DVI, DisplayPort, VGA
Display Position Adjustments
Tilt
Black/silver
74.188 cm x 17.82 cm x 51.69 cm
8 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, TUV GS, FCC, RoHS, TCO '06, DICOM Part 14, REACH, TUV Bauart, EuP, EAC
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC Pro-line U3277FWQ...
