AOC Pro-line U3277PWQU 31.5" 3840x2160 4ms HDMI DVI-D VG...
£399.98
Delivery:
  • Diagonal Size: 31.5in
  • Max Resolution: 3840 x 2160
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
Product codes
The AOC U3277PWQU helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals the finest details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction (95% NTSC and 100% sRGB, 1 billion colors), wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI-D makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video. Whether you're editing photography, working with CAD/CAM, or designing a website, the height-adjustable ergonomic stand tilts, swivels and pivots for hours of comfortable viewing.
Product Description AOC Pro-line U3277PWQU - LCD monitor - 4K - 31.5"
Device Type LCD monitor - 31.5"
Energy Class Class B
Energy Consumption per Year 74 kWh
Power Consumption (On mode) 51 W
Panel Type MVA
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Brightness 350 cd/m²
Contrast Ratio 3000:1 / 80000000:1 (dynamic)
Response Time 4 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors HDMI, DVI-D, VGA, DisplayPort, MHL
Display Position Adjustments Height, pivot (rotation)
Colour Black, silver
Dimensions (WxDxH) - with stand 74.2 cm x 17.1 cm x 65.9 cm
Weight 11.5 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV Bauart, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC Pro-line U3277PWQU...
£399.98
