The AOC U3277PWQU helps you stretch your productivity to the limits. 4K Ultra HD resolution reveals the finest details on a large 31.5-inch 16:9 screen that is ideal for multitasking. Featuring advanced AMVA panel technology, you'll enjoy accurate color reproduction (95% NTSC and 100% sRGB, 1 billion colors), wide viewing angles and quick refresh rates, no matter what you're doing. A range of connectors like HDMI 2.0, DisplayPort and DVI-D makes it easy to hook up your PC, laptop and other devices, plus built-in speakers deliver clear sound for music or video. Whether you're editing photography, working with CAD/CAM, or designing a website, the height-adjustable ergonomic stand tilts, swivels and pivots for hours of comfortable viewing.
Product Description | AOC Pro-line U3277PWQU - LCD monitor - 4K - 31.5" | Device Type | LCD monitor - 31.5" | Energy Class | Class B | Energy Consumption per Year | 74 kWh | Power Consumption (On mode) | 51 W | Panel Type | MVA | Aspect Ratio | 16:9 | Native Resolution | 4K 3840 x 2160 at 60 Hz | Brightness | 350 cd/m² | Contrast Ratio | 3000:1 / 80000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DVI-D, VGA, DisplayPort, MHL | Display Position Adjustments | Height, pivot (rotation) | Colour | Black, silver | Dimensions (WxDxH) - with stand | 74.2 cm x 17.1 cm x 65.9 cm | Weight | 11.5 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LCD monitor / TFT active matrix |
Diagonal Size | 31.5" |
Panel Type | MVA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Features | HDCP, i-Menu, e-Saver technology, Screen+ |
Dimensions (WxDxH) | 74.2 cm x 17.1 cm x 65.9 cm - with stand |
Weight | 11.5 kg |
Audio | |
Type | Speakers |
Output Power / Channel | 6 Watt |
Mechanical | |
Tilt Angle | -5/+24 |
Swivel Angle | 165 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately), VESA interface support |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x DisplayPort cable , 1 x audio cable |
Security Slot Type | Kensington security slot |
Power | |
Voltage Required | AC 100/240 V (50/60 Hz) |
Power Consumption Operational | 60 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.5 Watt |
On / Off Switch | Yes |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
