AOC Q2577Pwq 25" 2560x1440 5ms AH-IPS VGA DVI HDMI DP Mo...
AOC Q2577Pwq 25" 2560x1440 5ms AH-IPS VGA DVI HDMI DP Monitor
£255.98
Delivery:
Standard: 1-3 working days
Key features
  • Boasting a stunning quad HD resolution of 2560 x 1440 pixels
  • Ample screen real-estate with 25"
  • Diagonal Size: 25in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
  • Stock Status: In Stock
Product codes
The quad HD panel ensures that users can enjoy a full view of a website at a single glance without image distortion. IPS technology is one of the highest performing panel technologies currently available for displays. This way, AOC makes sure users will greatly benefit from high accuracy in color, contrast and wide viewing angles. The AOC Q2577PWQ comes with DisplayPort, HDMI, DVI and VGA. Also comes with a feature that ensures a zero-flickering viewing experience.
Product Description AOC Pro-line Q2577PWQ - LED monitor - 25"
Device Type LED-backlit LCD monitor - 25"
Energy Class Class B
Features Stereo speakers
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 2560 x 1440 at 60 Hz
Pixel Pitch 0.072 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 50000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, MHL, DVI, DisplayPort, VGA
Display Position Adjustments Swivel, tilt
Colour Black/silver
Dimensions (WxDxH) - with stand 57.04 cm x 19.91 cm x 47.48 cm
Weight 6.5 kg
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards TUV Bauart, EAC
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC Q2577Pwq 25" 2560x...
£255.98
