The quad HD panel ensures that users can enjoy a full view of a website at a single glance without image distortion. IPS technology is one of the highest performing panel technologies currently available for displays. This way, AOC makes sure users will greatly benefit from high accuracy in color, contrast and wide viewing angles. The AOC Q2577PWQ comes with DisplayPort, HDMI, DVI and VGA. Also comes with a feature that ensures a zero-flickering viewing experience.
Product Description | AOC Pro-line Q2577PWQ - LED monitor - 25" | Device Type | LED-backlit LCD monitor - 25" | Energy Class | Class B | Features | Stereo speakers | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 at 60 Hz | Pixel Pitch | 0.072 mm | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 5 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | HDMI, MHL, DVI, DisplayPort, VGA | Display Position Adjustments | Swivel, tilt | Colour | Black/silver | Dimensions (WxDxH) - with stand | 57.04 cm x 19.91 cm x 47.48 cm | Weight | 6.5 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 25" |
Viewable Size | 25" |
Built-in Devices | Stereo speakers |
Panel Type | IPS |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 99 kHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Built-in speakers |
Dimensions (WxDxH) | 57.04 cm x 19.91 cm x 47.48 cm - with stand |
Weight | 6.5 kg |
Connectivity | |
Interfaces | DVI , MHL / HDMI , VGA , DisplayPort |
Mechanical | |
Tilt Angle | -5/+23 |
Height Adjustment | 130 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x DVI cable , 1 x DisplayPort cable , 1 x power cable |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 55 Watt |
Power Consumption Stand by | 0.5 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
