AOC Q3279VWFD8 31.5" 2560x1440 5ms VGA DVI HDMI DisplayP...
AOC Q3279VWFD8 31.5" 2560x1440 5ms VGA DVI HDMI DisplayPort LED Monitor
£199.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • FreeSync technology
  • QHD - high resolution panel
  • Shadow Control
  • Game Color
  • Game Mode
  • 88% NTSC wide color gamut
  • Low blue light
  • Off timer
  • Digital inputs
  • Diagonal Size: 31.5in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Interfaces: DisplayPort, DVI, HDMI, Mobile High-Definition Link (MHL) + 1 more
  • Stock Status: In Stock
Product codes
A multi-purpose 31.5" Quad HD display, designed for gaming, entertainment, home use, and more. Comes with gaming enhancements like AMD FreeSync, AOC Shadow Control and Game Colour for better visual quality. For more general use, it also comes with Low Blue Light eye protection, Off Timer for power saving, and multiple digital inputs like Dual Link DVI and HDMI.
Product Description AOC Q3279VWFD8 - LED monitor - 31.5"
Device Type LED-backlit LCD monitor - 31.5"
Energy Class Class B
Energy Consumption per Year 67 kWh
Power Consumption (On mode) 46 W
Adaptive-Sync Technology AMD FreeSync
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 75 Hz
Pixel Pitch 0.273 mm
Brightness 250 cd/m²
Contrast Ratio 1200:1 / 80000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 1.073 billion colours (8-bit)
Input Connectors HDMI (MHL), VGA, DVI-D, DisplayPort
Display Position Adjustments Tilt
Dimensions (WxDxH) - with stand 72.96 cm x 15.32 cm x 53.3 cm
Weight 7 kg
Compliant Standards BSMI, CCC, FCC, RoHS, KCC, cTUVus, KC, RCM, ISO9241-307
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC Q3279VWFD8 31.5" 2...
£199.99
