Amazing picture quality, stunning design and a minimal footprint make the 23.8-inch I2481FXH a smart addition to your home or office. This display's ultra-slim 7.5mm profile and eye-catching base are sure to get people talking. The on-screen performance is just as impressive - the AH-IPS panel provides virtually borderless viewing and uniform colors from nearly any angle. With a built-in headphone jack and HDMI (x2) and VGA connectors, this monitor is also ideal for using multiple devices like computers and game consoles. Flicker-free technology optimizes the brightness to reduce eye strain, no matter what you're doing.
Product Description | AOC Style I2481FXH - LCD monitor - Full HD (1080p) - 23.8" | Device Type | LCD monitor - 23.8" | Energy Class | Class A | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 21 W | Panel Type | AH-IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, VGA | Display Position Adjustments | Tilt | Colour | Black | Dimensions (WxDxH) - with stand | 54.1 cm x 15 cm x 40.3 cm | Weight | 3.1 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LCD monitor / TFT active matrix |
Diagonal Size | 23.8" |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 170 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean |
Features | HDCP, i-Menu, e-Saver technology, Slim Design, Flicker Free technology |
Colour | Black |
Dimensions (WxDxH) | 54.1 cm x 15 cm x 40.3 cm - with stand |
Weight | 3.1 kg |
Connectivity | |
Interfaces | Audio line-out (mini-jack) , 2 x HDMI , VGA |
Mechanical | |
Tilt Angle | -3/+20 |
Miscellaneous | |
Cables Included | 1 x VGA cable , 1 x HDMI cable |
Power | |
Voltage Required | AC 100/120/230 V (50/60 Hz) |
Power Consumption Operational | 23 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption Sleep | 0.5 Watt |
On / Off Switch | No |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
