AOC Value i2080Sw 19.5" 1440x900 5ms VGA LED Monitor
£72.51
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 19.5in
  • Max Resolution: 1440 x 900
  • Response Time: 5ms
  • Interfaces: VGA (HD-15)
  • Stock Status: In Stock
Product codes
The 19.5-inch AOC I2080SW handles all your home computing needs with excellent performance and sharp, clear imagery. Featuring an IPS panel, you'll enjoy accurate colors, wide viewing angles and impressive picture quality, whether you're editing photos or just surfing the web. Fast response time eliminates blurring to deliver smooth action sequences for more exciting movies and games. This versatile home display makes the perfect addition to your home office or living room, and the integrated VESA mount also gives you the possibility to hang it on the wall. With the built-in VGA connector, you can hook up your computer and get started fast.
Product Description AOC Value i2080Sw - LED monitor - 19.5"
Device Type LED-backlit LCD monitor - 19.5"
Panel Type IPS
Aspect Ratio 16:10
Native Resolution 1440 x 900 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors VGA
Dimensions (WxDxH) - with stand 45.46 cm x 19 cm x 37.5 cm
Weight 2.14 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards Plug and Play, TUV, FCC, RoHS, REACH, EuP, EAC
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
AOC Value i2080Sw 19.5...
£72.51
