We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
With Full HD resolution and high contrast ratios, the 23.6-inch M2470SWH display offers brilliant picture quality and sharp, clear imagery - even on the darkest areas of the screen. Perfect for a range of home computing requirements, this monitor really excels at fast-paced entertainment like games and movies with ultra-fast 1 ms response time for lag-free action. Advanced MVA panel technology delivers ultra-wide viewing angles of 178 degrees to ensure you'll see every detail, no matter where you're sitting. Integrated VGA and HMDI ports make it easy to connect your computer, media center, game console and more, plus the built-in speakers and headphone jack are ideal for listening to music or catching up with friends.
Product Description | AOC M2470SWH - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Energy Class | Class F | Power Consumption (On mode) | 19.8 W | Panel Type | MVA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.2715 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Input Connectors | 2xHDMI, VGA | Speakers | Integrated | Voltage | AC 100/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 55.14 cm x 22.1 cm x 40.04 cm | Weight | 3.58 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | Plug and Play, TUV GS, FCC, RoHS, TUV Bauart, EAC | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Panel Type | MVA |
Vertical Refresh Rate | 50 - 76 Hz |
Horizontal Refresh Rate | 30 - 83 kHz |
Video Bandwidth | 165 MHz |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
Controls & Adjustments | Tilt |
OSD Languages | Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Finnish, Swedish, Russian, Spanish, Dutch, Japanese, Korean |
Features | HDCP, i-Menu, e-Saver technology, Screen+, i-Care |
Colour | Black |
Dimensions (WxDxH) | 55.14 cm x 22.1 cm x 40.04 cm - with stand |
Weight | 3.58 kg |
Audio | |
Type | Speakers - stereo - integrated |
Connectivity | |
Interfaces | VGA , 2 x HDMI , Headphones |
Mechanical | |
Tilt Angle | -5/+25 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | VESA interface support |
Cables Included | 1 x VGA cable , 1 x HDMI cable , 1 x power cable |
Power | |
Power Supply | Internal |
Input Voltage | AC 100/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 19.8 kWh/1000h |
Power Consumption (Typical) | 17.96 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.19 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
