No matter the task, the iPad Pro is up to it - and then some. It offers far more power than most PC laptops, yet is delightfully simple to use. The redesigned Retina display is as stunning to look at as it is to touch. And it all comes together with iOS, the world's most advanced mobile operating system. iPad Pro. Everything you want modern computing to be. Now even, well, better.
If you’re someplace where there is no Wi-Fi, iPad with Wi-Fi + Cellular models let you stay connected to fast cellular data networks practically anywhere you go. So you can continue to browse the web, send and receive mail, get directions, and more. To use a cellular network, simply insert an activated carrier SIM card, or purchase a cellular data plan using Apple SIM right on your iPad with no long-term commitment.
Product Description | Apple 10.5-inch iPad Pro Wi-Fi + Cellular - tablet - 256 GB - 10.5" - 3G, 4G | Product Type | Tablet | Display | 10.5" IPS TFT - LED backlight - 2224 x 1668 (264 ppi) - Multi-Touch | Processor | Apple A10X Fusion (6-core) - 64-bit | Storage | 256 GB | Cellular Technology | 3G, 4G | Cellular Protocols | GSM, UMTS, EDGE, CDMA 2000 1X EV-DO Rev. A, HSPA, HSPA+, LTE, DC-HSDPA, CDMA 2000 1X EV-DO Rev. B, LTE Advanced | Wireless Connectivity | 802.11a/b/g/n/ac, Bluetooth 4.2 | Camera | 12 Megapixel (rear), 7 Megapixel (front) | HD Video Recording | 4K | Navigation System | A-GPS/GLONASS | Security Devices | Fingerprint reader | Battery Run Time | Up to 10 hours | Dimensions (WxDxH) | 17.41 cm x 0.61 cm x 25.06 cm | Weight | 477 g | Colour | Gold | Localisation | English / United Kingdom | Manufacturer Warranty | 1-year warranty |
General | |
Operating System | Apple iOS 12 |
Display | |
Type | 10.5" IPS TFT - LED backlight |
Resolution | 2224 x 1668 (264 ppi) |
Touchscreen | Multi-Touch |
Features | Anti-glare, anti-reflective, anti-fingerprint, Retina display, fully laminated display, True Tone display, Wide colour display, ProMotion technology |
Processor | |
Processor | Apple A10X Fusion |
Number of Cores | 6-core |
64-bit Computing | Yes |
Memory | |
Storage | 256 GB |
Communications | |
Band | GSM 850/900/1800/1900 / UMTS 850/900/1700/1900/2100 / CDMA 2000 X1 800/1900 / LTE 700/700 APT/700b/700c/700 de/800/ 800 DD/850/900/1500/1800/1900/TD 1900/2100/2300/TD 2300/TD 2500/2600/TD 2600/AWS |
Camera | |
Resolution (MP) | 12 Megapixel (rear), 7 Megapixel (front) |
Lens Aperture | F/1.8 (rear) / f/2.2 (front) |
Digital Zoom | 5 |
Frame Rate | 60 frames per second |
Features | Video stabilizer, tap to focus, photo and video geotagging, autofocus, FaceTime HD camera, Burst mode, Slow motion video, noise reduction, sapphire crystal lens cover, backside illumination sensor, HDR (High Dynamic Range), Time-lapse mode, Focus Pixels, Panorama, Hybrid IR filter, Timer mode, Exposure control, Auto image stabilisation, Live Photo, Playback zoom, 8MP still photos while recording 4K video, 6-element lens, Retina Flash, body and face detection, optical image stabilisation, Quad-LED True Tone flash |
Navigation System | |
Receiver | A-GPS/GLONASS |
Multimedia | |
Supported Digital Audio Standards | WAV, AAC, AIFF, Audible, MP3, Apple Lossless, AC-3, HE-AAC, Audible AAX, Audible AAX+, protected AAC, EAC3, MP3 VBR |
Supported Digital Video Standards | MPEG-4 SP (up to 640x480), Motion JPEG (up to 1280x720), H.264 High Profile Level 4.2 (up to 4K) |
Audio | Two microphones, four speakers |
Input Device | |
Software | |
Preloaded Software | Clock, Mail, Notes, Calendar, Contacts, Messages, Camera, Files, FaceTime, Photo Booth, Safari, Photos, App Store, Maps, News, Find My iPhone, Stocks, Siri, Books, Reminders, Music, Find My Friends, Voice Memos, iTunes Store, Podcasts, Apple TV App, Home, Measure |
System Requirements for PC Connection | |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.9.5 or later |
Expansion and Connectivity | |
Interfaces | 1 x headphones mini jack (3.5mm) , 1 x Lightning , 1 x Smart Connector |
Battery | |
Technology | Lithium polymer |
Capacity | 30.4 Wh |
Run Time Details | Web browsing over Wi-Fi: up to 10 hour(s) , Video playback: up to 10 hour(s) , Audio playback: up to 10 hour(s) , Web browsing over cellular data network: up to 9 hour(s) |
Miscellaneous | |
Colour | Gold |
Sensors | Accelerometer, ambient light sensor, 3-axis gyro sensor, digital compass, barometer |
Features | Charging via USB, VoiceOver screen reader, AirPrint, AirPlay, parental controls, Dictation, AssistiveTouch, MIMO technology, AirDrop, iBeacon microlocation, Family Sharing, Night Shift, Apple M10 motion coprocessor |
Included Accessories | Power adapter |
Cables Included | Lightning to USB cable |
Dimensions & Weight | |
Width | 17.41 cm |
Depth | 0.61 cm |
Height | 25.06 cm |
Weight | 477 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 45 °C |
Max Altitude Operating | 3 km |
