MacBook Air is designed to be powerful, capable, durable, and enjoyable to use. With enough battery life to get you through the day. That's the difference between a notebook that's simply thin and light and one that's so much more.
Multi-Touch technology is part of practically every Apple product. It's the best and most personal way to interact with your devices. And the optimal way to experience Multi-Touch on a notebook is through a trackpad. That's precisely the case with MacBook Air. The trackpad's spacious, all-glass surface doesn't have a button because the whole thing is the button. And with multi-touch gestures in OS X, you can interact with MacBook Air in ways that feel more intuitive and realistic than ever before.
MacBook Air features a unibody design for both the main enclosure and the display. Unibody construction means a higher-precision, less complex design with fewer parts. That translates to a notebook that's exceptionally thin and light, yet durable enough to handle the rigors of everyday use. In addition, MacBook Air offers innovations you won't find anywhere else.
Product Description | Apple MacBook Air with Retina display - 13.3" - Core i5 - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | macOS Catalina 10.15 | Processor | Intel Core i5 (8th Gen) 1.6 GHz (3.6 GHz) / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Optical Drive | No optical drive | Display | 13.3" LED backlight 2560 x 1600 / WQXGA | Graphics | Intel UHD Graphics 617 | Input Device | Force Touch trackpad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | Up to 12 hours | Security | Fingerprint reader | Colour | Space grey | Dimensions (WxDxH) | 30.41 cm x 21.24 cm x 1.56 cm | Weight | 1.25 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
General | |
Operating System | Apple macOS Catalina 10.15 |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 1.6 GHz |
Max Turbo Speed | 3.6 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Max RAM Supported | 16 GB |
Technology | LPDDR3 SDRAM |
Speed | 2133 MHz |
Storage | |
Main Storage | 256 GB SSD - (soldered) PCIe |
Display | |
Type | 13.3" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 2560 x 1600 (WQXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Features | BFR/PVC-free, Mercury free, beryllium free, arsenic free, 227 ppi |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 617 |
Camera | Yes - 720p |
Camera Features | FaceTime HD camera |
Sound | Stereo speakers, three microphones |
Input | |
Type | Keyboard, Force Touch trackpad |
Keyboard Layout | UK |
Features | Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Battery | |
Technology | Lithium polymer |
Capacity | 50.3 Wh |
Run Time | Up to 12 hours |
Battery Run Time | Web browsing over Wi-Fi: up to 12 hours , Video playback: up to 13 hours , Standby time: up to 30 days |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 30 Watt |
Connections & Expansion | |
Interfaces | 2 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , Headphone output |
Software | |
Software Included | iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Preview, Mail, Maps, Photos, Reminders, App Store, Contacts, Stocks, Notes, Calendar, Siri, Messages, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers, News, Voice Memos, Home |
Miscellaneous | |
Case Material | Aluminum |
Features | T2 Security Chip |
Included Accessories | USB-C power adapter |
Cables Included | USB-C charge cable |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.25 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
