Apple 13" MacBook Air: 1.6GHz Intel Core i5 256GB - Spac...
Key features
  • Advanced technology from iPad
  • The best way to multi-touch on a notebook
  • An incredible battery
  • UniKeySellingPoints in unison
Product codes
MacBook Air is designed to be powerful, capable, durable, and enjoyable to use. With enough battery life to get you through the day. That's the difference between a notebook that's simply thin and light and one that's so much more.
Multi-Touch technology is part of practically every Apple product. It's the best and most personal way to interact with your devices. And the optimal way to experience Multi-Touch on a notebook is through a trackpad. That's precisely the case with MacBook Air. The trackpad's spacious, all-glass surface doesn't have a button because the whole thing is the button. And with multi-touch gestures in OS X, you can interact with MacBook Air in ways that feel more intuitive and realistic than ever before.
MacBook Air features a unibody design for both the main enclosure and the display. Unibody construction means a higher-precision, less complex design with fewer parts. That translates to a notebook that's exceptionally thin and light, yet durable enough to handle the rigors of everyday use. In addition, MacBook Air offers innovations you won't find anywhere else.
Product Description Apple MacBook Air with Retina display - 13.3" - Core i5 - 8 GB RAM - 256 GB SSD - QWERTY UK
Product Type Notebook
Operating System Apple macOS Mojave 10.14
Processor Intel Core i5 (8th Gen) 1.6 GHz (3.6 GHz) / 4 MB Cache
Memory 8 GB LPDDR3 (provided memory is soldered)
Storage 256 GB - soldered SSD
Optical Drive No optical drive
Display 13.3" LED backlight 2560 x 1600 / WQXGA
Graphics Intel UHD Graphics 617
Input Device Force Touch trackpad
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery Up to 12 hours
Security Fingerprint reader
Colour Space grey
Dimensions (WxDxH) 30.41 cm x 21.24 cm x 1.56 cm
Weight 1.25 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 1 year , Technical support - phone consulting - 90 days
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple 13" MacBook Air:...
