Apple 13-inch MacBook Pro with Touch Bar: 2.3GHz Quad-Core i5...
Key features
  • Eye-opening graphics performance
  • Make quicker work of everything
  • Powerful and versatile port
  • Music to your ears
Product codes
More power. More performance. More pro.
  • New eighth-generation Intel 6-core and quad-core processors.
  • Up to 32GB of memory for running multiple pro apps.
  • Stunning Retina display with True Tone technology.
  • Touch Bar for working more productively.
With great power comes great capability.
MacBook Pro elevates the notebook to a whole new level of performance and portability. Wherever your ideas take you, you’ll get there faster than ever with high-performance processors and memory, advanced graphics, amazingly fast storage and more.
More power at its cores.
With eighth-generation Intel Core processors, MacBook Pro reaches new heights in compute performance. The 15-inch model now features a 6-core Intel Core processor that works up to 70 per cent faster than the previous generation, enabling up to 4.8GHz Turbo Boost speeds. And a quad-core processor on the 13-inch MacBook Pro with Touch Bar now makes it up to twice as fast as the previous generation. So when you’re powering through pro-level processing jobs like compiling code, rendering 3D models, adding special effects, layering multiple tracks or encoding video, you’ll get everything done. Faster.
Eye-opening graphics performance.
MacBook Pro features a Radeon Pro discrete GPU in every 15-inch model, combining impressive power with remarkable power efficiency. And now we’ve paired each discrete GPU with 4GB of GDDR5 memory as standard, giving you fluid, real-time performance for pro tasks like rendering 3D titles in Final Cut Pro X. The 13-inch model with Touch Bar features powerful integrated graphics with 128MB of embedded DRAM — twice as much as the previous generation — which accelerates graphics tasks. That means more time for what matters most — creating amazing work.
Product Description Apple MacBook Pro with Touch Bar - 13.3" - Core i5 - 8 GB RAM - 256 GB SSD - UK
Product Type Notebook
Operating System macOS Catalina 10.15
Processor Intel Core i5 (8th Gen) 2.3 GHz (3.8 GHz)
Memory 8 GB LPDDR3 (provided memory is soldered)
Storage 256 GB SSD
Optical Drive No optical drive
Display 13.3" LED backlight 2560 x 1600 / WQXGA - 227 ppi
Graphics Intel Iris Plus Graphics 655
Input Device Force Touch trackpad, Touch Bar
Keyboard UK
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 5.0
Battery Up to 10 hours
Security Fingerprint reader
Colour Space grey
Dimensions (WxDxH) 30.41 cm x 21.24 cm x 1.49 cm
Weight 1.37 kg
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
SAR 0.9 W/kg (body)
Manufacturer Warranty Limited warranty - 1 year , Technical support - phone consulting - 90 days
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
