More power. More performance. More pro.
With great power comes great capability.
MacBook Pro elevates the notebook to a whole new level of performance and portability. Wherever your ideas take you, you’ll get there faster than ever with high-performance processors and memory, advanced graphics, amazingly fast storage and more.
More power at its cores.
With eighth-generation Intel Core processors, MacBook Pro reaches new heights in compute performance. The 15-inch model now features a 6-core Intel Core processor that works up to 70 per cent faster than the previous generation, enabling up to 4.8GHz Turbo Boost speeds. And a quad-core processor on the 13-inch MacBook Pro with Touch Bar now makes it up to twice as fast as the previous generation. So when you’re powering through pro-level processing jobs like compiling code, rendering 3D models, adding special effects, layering multiple tracks or encoding video, you’ll get everything done. Faster.
Eye-opening graphics performance.
MacBook Pro features a Radeon Pro discrete GPU in every 15-inch model, combining impressive power with remarkable power efficiency. And now we’ve paired each discrete GPU with 4GB of GDDR5 memory as standard, giving you fluid, real-time performance for pro tasks like rendering 3D titles in Final Cut Pro X. The 13-inch model with Touch Bar features powerful integrated graphics with 128MB of embedded DRAM — twice as much as the previous generation — which accelerates graphics tasks. That means more time for what matters most — creating amazing work.
Product Description | Apple MacBook Pro with Touch Bar - 15.4" - Core i7 - 16 GB RAM - 512 GB SSD - UK | Product Type | Notebook | Operating System | macOS Catalina 10.15 | Processor | Intel Core i7 (8th Gen) 2.6 GHz (4.3 GHz) / 9 MB Cache | Memory | 16 GB DDR4 (provided memory is soldered) | Storage | 512 GB SSD | Optical Drive | No optical drive | Display | 15.4" LED backlight 2880 x 1800 / WQXGA+ | Graphics | AMD Radeon Pro 560X / Intel UHD Graphics 630 | Video Memory | 4 GB GDDR5 SDRAM | Input Device | Force Touch trackpad, Touch Bar | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0 | Battery | Up to 10 hours | Security | Fingerprint reader | Colour | Space grey | Dimensions (WxDxH) | 34.93 cm x 24.07 cm x 1.55 cm | Weight | 1.83 kg | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
General | |
Operating System | Apple macOS Catalina 10.15 |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 2.6 GHz |
Max Turbo Speed | 4.3 GHz |
Number of Cores | 6-core |
Cache | L3 - 9 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology |
Memory | |
RAM | 16 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Speed | 2400 MHz |
Storage | |
Main Storage | 512 GB SSD - (soldered) |
Display | |
Type | 15.4" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 2880 x 1800 (WQXGA+) |
Widescreen | Yes |
Image Brightness | 500 cd/m² |
Features | BFR/PVC-free, Mercury free, Wide Colour Gamut, arsenic-free glass, 220 ppi, beryllium free, Retina display, True Tone display |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | AMD Radeon Pro 560X / Intel UHD Graphics 630 |
Camera | Yes - 720p |
Camera Features | FaceTime HD camera |
Sound | Stereo speakers, three microphones |
Input | |
Type | Keyboard, Force Touch trackpad, Touch Bar |
Keyboard Layout | UK |
Features | Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, Touch ID sensor |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Battery | |
Technology | Lithium polymer |
Capacity | 83.6 Wh |
Run Time | Up to 10 hours |
Battery Run Time | Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 10 hours , Standby time: up to 30 days |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 87 Watt |
Connections & Expansion | |
Interfaces | 4 x USB-C 3.1 Gen 2/Thunderbolt 3/DisplayPort (Power Delivery) , Headphone output |
Software | |
Software Included | Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple Mac OS X Mail, Apple Mac OS X Chess, Apple iMovie, Apple DVD Player, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple Mac App Store, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Maps, Reminders, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers |
Miscellaneous | |
Case Material | Aluminum |
Included Accessories | USB-C power adapter |
Cables Included | USB-C charge cable |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 1.83 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
