Apple AirPods - 1st Generation
Sorry but this product has been discontinued.
View used stock
Key features
  • Automatically on, automatically connected
  • Easy setup for all your Apple devices
  • Double-tap to play or skip forward
  • Charges quickly in the case
  • Rich, high-quality audio and voice
  • Seamless switching between devices
  • Accessory Type: Earphones
  • Connectivity: Wireless
  • Colour: White
  • Stock Status: Clearance, Used Stock
Product codes
Just take them out and they're ready to use with all your devices. Put them in your ears and they connect instantly. Speak into them and your voice sounds clear. Introducing AirPods. Simplicity and technology, together like never before. The result is completely magical.
Product Description Apple AirPods - true wireless earphones with mic
Product Type True wireless earphones - Bluetooth
Compatibility iPhone, iPad, iPod, Mac
Recommended Use Portable electronics
Headphones Form Factor Ear-bud
Wireless Technology Bluetooth
Sound Output Mode Stereo
Controls Volume, answer/end, next/previous track
Designed For 10.5-inch iPad Pro; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad (5th generation, 6th generation); 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; iPhone 11, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod touch (6G); TV; Watch
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: DYZP 041087
£97.81
product
Ref: DYZP 041087
Accessories
Packaging
Functional
Software
Manuals
£97.81
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple AirPods - 1st Ge...
