We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Marketing description is not available.
Product Description | Apple AirPods Max - headphones with mic | Product Type | Headphones - Bluetooth - wireless | Compatibility | iPhone, iPad, iPod, Mac | Recommended Use | Portable electronics, computer | Additional Functions | Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking | Colour | Sky blue | Headphones Form Factor | Full size | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Sound Effects | Adaptive EQ | Active Noise Canceling | Yes | Microphones Included | 9 | Controls | Volume, play/pause, next/previous track, voice assistant, answer call, ANC/transparency | Intelligent Assistant | Siri | Manufacturer Warranty | 1-year warranty | Designed For | 10.2-inch iPad; 10.5-inch iPad Air; 10.5-inch iPad Pro; 10.9-inch iPad Air; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iMac; iMac Pro; iPad Air 2; iPad mini; iPad mini 4; 5; iPhone 11, 12, 13, 6s, 7, 8, SE, X, XR, XS, XS Max; Mac mini; MacBook Air; MacBook Pro; TV 4K, HD |
General | |
Dimensions & Weight Details | Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 384.8 g , Case: 134.5 g |
Width | 16.86 cm |
Depth | 8.34 cm |
Height | 18.73 cm |
Weight | 384.8 g |
Colour | Sky blue |
Body Material | Stainless steel, anodised aluminium |
Headband Material | Knit mesh |
Earpad Material | Memory foam, mesh textile |
Features | On-ear detection |
Audio Output | |
Magnet Material | Neodymium magnet |
Adjustable Headband | Yes |
Features | Apple H1 chip |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Tracking | |
Sensors | Accelerometer, gyro sensor, position sensor, optical sensor, case-detect sensor |
Internet of Things (IoT) | |
Miscellaneous | |
Included Accessories | Charging case, Lightning to USB-C cable |
Cable Details | USB-C to Lightning cable - detachable |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 20 hour(s) |
Run Time Details | Continuous playback (active noise-cancelling on): up to 20 hours , Continuous playback (spatial audio on): up to 20 hours , Continuous talk: up to 20 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
Designed For | Apple 10.2-inch iPad (7th generation, 8th generation, 9th generation) , Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 10.9-inch iPad Air (4th generation) , Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation, 4th generation, 5th generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iMac (Early 2019, Early 2021, Late 2012, Late 2013, Late 2014, Late 2015, Mid 2014, Mid 2015, Mid 2017, Mid 2020) , Apple iMac Pro (Late 2017) , Apple iPad Air 2 , Apple iPad mini (6th generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPhone 11, 11 Pro, 11 Pro Max, 12, 12 mini, 12 Pro, 12 Pro Max, 13, 13 mini, 13 Pro, 13 Pro Max, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, SE (2nd generation), X, XR, XS, XS Max , Apple iPod touch (7G) , Apple Mac mini (Early 2020, Late 2012, Late 2014, Late 2018, Late 2020) , Apple Mac Pro (Late 2013, Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2014, Early 2015, Early 2020, Late 2018, Late 2020, Mid 2012, Mid 2013, Mid 2017, Mid 2019) , Apple MacBook Pro (Early 2013, Early 2015, Early 2020, Late 2012, Late 2013, Late 2016, Late 2019, Late 2020, Late 2021, Mid 2014, Mid 2015, Mid 2017, Mid 2018, Mid 2019) , Apple TV 4K, HD , Apple Watch |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
