More magical than ever.
Now with more talk time, voice-activated Siri access — and a new wireless charging case — AirPods deliver an unparalleled wireless headphone experience. Simply take them out and they’re ready to use with all your devices. Put them in your ears and they connect immediately, immersing you in rich, high-quality sound. Just like magic.
Product Description | Apple AirPods with Wireless Charging Case - 2nd Generation - true wireless earphones with mic | Product Type | True wireless earphones - Bluetooth | Compatibility | iPhone, iPad, iPod, Mac | Recommended Use | Portable electronics | Headphones Form Factor | Ear-bud | Wireless Technology | Bluetooth | Sound Output Mode | Stereo | Controls | Volume, answer/end, next/previous track | Intelligent Assistant | Siri | Designed For | 10.2-inch iPad (7th generation); 10.5-inch iPad Pro; 11-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air 2; iPad mini 4; 5; iPhone 11, 11 Pro, 11 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod touch (7G); TV; Watch |
General | |
Product Type | True wireless earphones - Bluetooth - wireless |
Dimensions & Weight Details | Charging case: 4.43 cm x 2.13 cm x 5.35 cm / 40 g |
Width | 1.65 cm |
Depth | 1.8 cm |
Height | 4.05 cm |
Weight | 4 g |
Headphones | |
Connectivity Technology | Wireless |
Features | Apple H1 chip |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Tracking | |
Sensors | Dual optical sensors, motion-detecting accelerometer, speech-detecting accelerometer |
Internet of Things (IoT) | |
Intelligent Assistant Compatible | Siri |
Miscellaneous | |
Included Accessories | Lightning cable, wireless charging case |
Power | |
Auto On/Off | Yes |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 5 hour(s) |
Run Time Details | Continuous playback: up to 5 hrs , Continuous talk: up to 3 hrs |
Compatibility Information | |
Designed For | Apple 10.2-inch iPad (7th generation) , Apple 10.5-inch iPad Pro , Apple 11-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation, 3rd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air 2 , Apple iPad mini 4 , Apple iPad mini 5 , Apple iPhone 11, 11 Pro, 11 Pro Max, 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max , Apple iPod touch (7G) , Apple TV , Apple Watch |
Customer return - item has been used and shows signs of use.
Ref: F48G 041344 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£149.28
