Apple Apple MagSafe Power Adapter - 85W (MacBook Pro 2010)
£75.06
10 in stock
Delivery:
Standard: 1-3 working days
  • Device Type: Macbook
  • Type: Power Adapters
  • Device Screen Size: [N/A]
  • Colour: White
  • Stock Status: In Stock
Product codes
Bundle deals (1)
JUICE 1M LIGHTNING CABLE
= £81.04
Save £9.00
The 85 W MagSafe power adapter features a magnetic DC connector that ensures your power cable will disconnect if it experiences undue strain and helps prevent fraying or weakening of the cables over time. In addition, the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector will light. An AC cord is provided with the adapter for maximum cord length, while the AC wall adapter gives users an even easier and more compact way to travel.
Designed to be the perfect traveling companion, the adapter has a clever design which allows the DC cable to be wound neatly around itself for easy cable storage.
This power adapter recharges the lithium polymer battery while the system is off, on, or in sleep mode. It also powers the system if you choose to operate without a battery.
Product Description Apple MagSafe - power adapter - 85 Watt
Device Type Power adapter - external
Power Capacity 85 Watt
Designed For MacBook Pro 15" (Mid 2012, Late 2011, Early 2011, Mid 2010); MacBook Pro 17" (Late 2011, Early 2011, Mid 2010)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Apple MagSafe Po...
£75.06
