Apple iMac 21.5-inch with Retina 4K display 3.4GHz quad-core i5
£1,199.98
Delivery:
Key features
  • Performance boosts across the board
  • Graphics that render you speechless
  • Accelerate your every move
  • Storage that's lightning fast
  • Brighter than ever, more colors than ever
  • The color you shoot is the color you see
  • Double the speed and bandwidth of the previous generation
  • Advanced engineering, talk about modern art
  • Operating System: Apple macOS Catalina 10.15
  • Processor Type: Core i5
  • Installed Memory: 8GB
  • Hard Drive Capacity: 1TB
  • Storage Type: Hybrid Drive
Product codes
Faster and more powerful than ever, iMac is now equipped with seventh-generation Intel Core i5 processors and the latest high-performance graphics. Storage kicks into high gear as well, with the speedy and spacious Fusion Drive now available in standard configurations of Retina models. So you can do everything you love to do on iMac.
iMac features powerful Radeon Pro 500 series graphics that make a spectacle of everything you see. The Retina 5K display is loaded with up to 8GB of dedicated VRAM. And Retina 4K display ignites with up to 4GB. Both deliver visual effects and 3D graphics that exhibit raw power in its most polished form. On top of that, you get advanced video editing capabilities. Now you can edit multicam projects in Final Cut Pro X with up to five streams of full-resolution 4K video.
An all-new seventh-generation Intel Core processor in every iMac. And Turbo Boost gives you even more power when you're using processor-intensive applications like Logic Pro or Final Cut Pro. It all takes place behind the scenes, but you'll see the difference in so many ways.
Product Description Apple iMac with Retina 4K display - all-in-one - Core i5 3.4 GHz - 8 GB - 1 TB - LED 21.5" - UK
Type Personal computer - all-in-one
Localisation Language: English / region: United Kingdom
Processor 1 x Intel Core i5 (7th Gen) 3.4 GHz (3.8 GHz) (Quad-Core)
Processor Main Features Intel Turbo Boost Technology 2
RAM 8 GB (installed) / 32 GB (max) - DDR4 SDRAM - non-ECC
Hard Drive 1 x Hybrid Drive 1 TB - SATA
Optical Storage No optical drive
Card Reader Yes
Monitor 21.5" - LED - 4096 x 2304 (4K)
Graphics Controller AMD Radeon Pro 560
Video Memory 4 GB VRAM
Camera Yes
Audio Output Stereo
Networking GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2
Keyboard UK
Power AC 120/230 V (50/60 Hz)
OS Provided Apple macOS Catalina 10.15
Dimensions (WxDxH) 52.8 cm x 17.5 cm x 45 cm
Weight 5.66 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 1 year , Technical support - phone consulting - 90 days
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple iMac 21.5-inch w...
£1,199.98
