Now equipped with seventh-generation Intel Core processors, MacBook is snappier than ever. From daily tasks like launching apps and opening files to more advanced computing, you can power through your day thanks to faster SSDs and Turbo Boost processing up to 3.6GHz.
MacBook was built for virtually silent performance. Its processor runs on just 5 watts of power, which generates less heat and eliminates the need for a fan to cool the computer. Instead, the logic board is seated on an anisotropic graphite sheet that helps disperse any heat. So you won't hear a thing while your MacBook is hard at work. Though its components are tiny, MacBook has an impressive capacity to store the files and run the applications you need every day.
Product Description | Apple MacBook - 12" - Core m3 - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | macOS Catalina 10.15 | Processor | Intel Core m3 (7th Gen) 1.2 GHz (3 GHz) / 4 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Optical Drive | No optical drive | Display | 12" LED backlight 2304 x 1440 | Graphics | Intel HD Graphics 615 | Input Device | Force Touch trackpad | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2 | Battery | Up to 12 hours | Colour | Space grey | Dimensions (WxDxH) | 28.05 cm x 19.65 cm x 1.31 cm | Weight | 920 g | Localisation | Language: English / region: United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
General | |
Operating System | Apple macOS Catalina 10.15 |
Processor / Chipset | |
CPU | Intel Core m3 (7th Gen) 1.2 GHz |
Max Turbo Speed | 3 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 4 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD - (soldered) PCIe |
Display | |
Type | 12" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 2304 x 1440 |
Widescreen | Yes |
Image Aspect Ratio | 16:10 |
Features | BFR/PVC-free, Mercury free, 226 ppi, arsenic-free glass, beryllium free, 178° horizontal and vertical viewing angle |
Audio & Video | |
Graphics Processor | Intel HD Graphics 615 |
Camera | Yes - 480p |
Sound | Stereo speakers, two microphones |
Input | |
Type | Keyboard, Force Touch trackpad |
Keyboard Layout | UK |
Features | Pressure sensitivity, multi-touch touchpad, Multi-Touch Gesture Recognition, ambient light sensor, force click, 12 function keys |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Battery | |
Technology | Lithium polymer |
Capacity | 41.4 Wh |
Run Time | Up to 12 hours |
Battery Run Time | Web browsing over Wi-Fi: up to 10 hours , Video playback: up to 12 hours , Standby time: up to 30 days |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 29 Watt |
Connections & Expansion | |
Interfaces | USB-C 3.1 Gen 1/DisplayPort 1.2 , Headphone output |
Software | |
Software Included | Drivers & Utilities, Apple QuickTime, Apple iTunes, Apple iMovie, Apple Safari, Apple GarageBand, Apple Dashboard, Photo Booth, Apple Time Machine, Apple FaceTime, Apple Automator, Apple Launchpad, Apple Mission Control, Apple Preview, Apple Calculator, Apple Dictionary, Apple Image Capture, Apple Stickies, Apple TextEdit, Apple System Preferences, Mail, Maps, Photos, Reminders, App Store, Contacts, Notes, Calendar, Apple AirDrop, Siri, Notification Center, Messages, Dictation, iCloud, Game Center, Apple AirPlay, Apple Font Book, Apple iBooks, Apple Keynote, Apple Pages, Apple Numbers |
Miscellaneous | |
Case Material | Aluminum |
Included Accessories | USB-C power adapter |
Cables Included | USB-C charge cable |
Localization | Language: English / region: United Kingdom |
Dimensions & Weight | |
Weight | 920 g |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
