Apple MacBook 12" 1.2GHz dual-core Intel Core m3 256GB -...
Apple MacBook 12" 1.2GHz dual-core Intel Core m3 256GB - Space Grey
Colours:
Key features
  • More muscle in every millimeter
  • Fanless architecture
  • Storage and memory
  • A Retina display that takes everything to the edge
  • A keyboard refined for an even better hands-on experience
  • Enhanced butterfly mechanism
  • Press a little deeper, do a lot more
  • Precise control at your fingertips
  • Connect to everything you love
Product codes
Now equipped with seventh-generation Intel Core processors, MacBook is snappier than ever. From daily tasks like launching apps and opening files to more advanced computing, you can power through your day thanks to faster SSDs and Turbo Boost processing up to 3.6GHz.
MacBook was built for virtually silent performance. Its processor runs on just 5 watts of power, which generates less heat and eliminates the need for a fan to cool the computer. Instead, the logic board is seated on an anisotropic graphite sheet that helps disperse any heat. So you won't hear a thing while your MacBook is hard at work. Though its components are tiny, MacBook has an impressive capacity to store the files and run the applications you need every day.
Product Description Apple MacBook - 12" - Core m3 - 8 GB RAM - 256 GB SSD - UK
Product Type Notebook
Operating System macOS Catalina 10.15
Processor Intel Core m3 (7th Gen) 1.2 GHz (3 GHz) / 4 MB Cache
Memory 8 GB LPDDR3 (provided memory is soldered)
Storage 256 GB SSD
Optical Drive No optical drive
Display 12" LED backlight 2304 x 1440
Graphics Intel HD Graphics 615
Input Device Force Touch trackpad
Keyboard UK
Keyboard Backlight Yes
Integrated Webcam Yes
Networking 802.11a/b/g/n/ac, Bluetooth 4.2
Battery Up to 12 hours
Colour Space grey
Dimensions (WxDxH) 28.05 cm x 19.65 cm x 1.31 cm
Weight 920 g
Localisation Language: English / region: United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty Limited warranty - 1 year , Technical support - phone consulting - 90 days
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple MacBook 12" 1.2G...
