Apple Magic Keyboard for iPad Pro 12.9-inch
19 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Comfortable backlit keys and a scissor mechanism with 1 mm travel for quiet, responsive typing
  • Designed for Multi-Touch gestures and the cursor in iPadOS
  • Smooth angle adjustability delivers the perfect viewing angle
  • USB-C port for charging iPad Pro and iPad Air, freeing up the port on the iPad for other accessories
  • Folds into a case to provide front and back protection for traveling with iPad Pro and iPad Air
Product codes
The Magic Keyboard is an amazing companion for iPad Pro and iPad Air. It features an incredible typing experience, a trackpad that opens up new ways to work with iPadOS, a USB-C port for passthrough charging, and front and back protection. The Magic Keyboard has a floating cantilever design, allowing you to attach iPad Pro and iPad Air magnetically and to smoothly adjust it to the perfect viewing angle for you.
  • Comfortable backlit keys and a scissor mechanism with 1mm travel for quiet, responsive typing.
  • Designed for Multi-Touch gestures and the cursor in iPadOS.
  • Smooth angle adjustability delivers the perfect viewing angle.
  • USB-C port for charging iPad Pro, freeing up the port on the iPad for other accessories.
  • Folds into a case to provide front and back protection for travelling with iPad Pro.
iPad Pro 12.9-inch (3rd, 4th, 5th or 6th generation) running iPadOS 14.5 or later.
iPad Models
  • iPad Pro 12.9-inch (6th generation)
  • iPad Pro 12.9-inch (5th generation)
  • iPad Pro 12.9-inch (4th generation)
  • iPad Pro 12.9-inch (3rd generation)
Product Description Apple Magic Keyboard - keyboard and folio case - with trackpad - QWERTY - UK - white
Device Type Keyboard and folio case
Backlit Yes
Interface Apple Smart connector
Input Device Keyboard
Connectivity Technology Wired
Built-in Devices Trackpad
Localization and Layout QWERTY UK
Colour White
Designed For 12.9-inch iPad Pro (3rd generation, 4th generation, 5th generation)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£379.00
