Apple Magic Mouse 2
Apple Magic Mouse 2
£66.91
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Magic is in the multi-touch
  • One or two, left or right
  • Laser tracking engine
  • Bluetooth technology
  • Wired / Wireless: Wireless
  • Compatibility: Mac
  • Stock Status: In Stock, Used Stock
Product codes
Featuring impressive design, Magic Mouse 2 is completely rechargeable, so you'll eliminate the use of traditional batteries. It's lighter, has fewer moving parts thanks to its built-in battery and continuous bottom shell, and has an optimized foot design - all helping Magic Mouse 2 track easier and move with less resistance across your desk. And the multi-touch surface allows you to perform simple gestures such as swiping between web pages and scrolling through documents. Magic Mouse 2 is ready to go right out of the box and pairs automatically with your Mac.
Product Description Apple Magic Mouse 2 - mouse - Bluetooth
Device Type Mouse
Connectivity Technology Wireless - Bluetooth
Dimensions (WxDxH) 5.71 cm x 11.35 cm x 2.16 cm
Weight 99 g
Multi-Touch Yes
Features Scrolling, gesture function
OS Required Apple MacOS X 10.11 or later
Designed For iMac; Mac mini (Late 2012, Late 2014, Mid 2011); Mac Pro (Mid 2012); MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air (Early 2014, Early 2015, Mid 2011, Mid 2012, Mid 2013, Mid 2014, Mid 2017); MacBook Pro
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: BQBX 040792
£36.34
product
Ref: BQBX 040792
Accessories
Packaging
Functional
Software
Manuals
£36.34
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Magic Mouse 2
£66.91
