Apple MagSafe 2 Power Adapter - 85W Euro Connector
£74.78
Delivery:
  • Device Type: Macbook
  • Type: Power
  • Device Screen Size: [N/A]
  • Colour: [N/A]
Product codes
The MagSafe 2 Power Adapter features a magnetic DC connector, so if someone trips over it, the lead disconnects harmlessly and your MacBook Pro stays put safely. It also helps prevent fraying or weakening of the cables over time. And the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector lights up; amber light lets you know that your notebook is charging, while a green light tells you that you have a full charge. An AC lead is provided with the adapter for maximum lead length, while the AC wall adapter (also provided) gives you an even easier and more compact way to travel.
Designed to be the perfect traveling companion, the adapter has a clever design that allows the DC cable to be wound neatly around itself for easy cable storage. This power adapter recharges the lithium polymer battery while the system is off, on or in sleep mode. It also powers the system if you choose to operate without a battery.
Product Description Apple MagSafe 2 - power adapter - 85 Watt
Device Type Power adapter - external
Power Capacity 85 Watt
Included Accessories Power plug adapter (EU)
Designed For MacBook Pro with Retina display 15.4" (Mid 2012, Early 2013, Late 2013, Mid 2014, Mid 2015)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple MagSafe 2 Power...
£74.78
