Apple Magsafe Power Adapter - 45W (MacBook Air)
£74.78
16 in stock
Delivery:
Standard: 1-3 working days
  • Device Type: Macbook
  • Type: Power
  • Device Screen Size: [N/A]
  • Colour: [N/A]
  • Stock Status: In Stock
Product codes
The 45-watt MagSafe power adapter for MacBook Air features a magnetic DC connector that ensures your power cable will disconnect if it experiences undue strain and helps prevent fraying or weakening of the cables over time. In addition, the magnetic DC helps guide the plug into the system for a quick and secure connection.
When the connection is secure, an LED located at the head of the DC connector will light; an amber light lets you know that your portable is charging, while a green light tells you that you have a full charge.
Redesigned specifically for MacBook Air, the adapter is the perfect traveling companion. It has a clever design which allows the DC cable to be wound neatly around itself for easy cable storage.
This power adapter recharges the lithium polymer battery while the system is off, on, or in sleep mode. It also powers the system if you choose to operate without a battery.
Product Description Apple MagSafe - power adapter - 45 Watt
Device Type Power adapter - external
Localisation United Kingdom
Power Capacity 45 Watt
Designed For MacBook Air 11" (Mid 2011, Late 2010); MacBook Air 13" (Mid 2011, Late 2010)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Magsafe Power Ad...
£74.78
