Apple Mini DisplayPort to DVI Adapter
£27.55
Delivery:
Product codes
Every Mac with a Mini DisplayPort allows you to connect an external display or projector using an adapter. You can use an external display as your main workspace or to extend your desktop, or you can work in mirrored mode with a projector so you can view what your audience sees.
The Apple Mini DisplayPort to dual-link DVI adapter works best with displays that operate at dual-link resolutions, which are resolutions above 1920 x 1200. For displays that do not support dual-link DVI resolutions (displays that operate at resolutions of 1920 x 1200 or lower) you should use the Apple Mini DisplayPort to DVI adapter.
Product Description Apple DVI adapter
Type DVI adapter
Connector Mini DisplayPort - male
Connector (Second End) DVI-D - female
Designed For iMac; Mac mini (Early 2009, Late 2009, Late 2012, Late 2014, Mid 2010, Mid 2011); MacBook (Late 2008, Late 2009, Mid 2010); MacBook Air (Early 2014, Early 2015, Late 2008, Late 2010, Mid 2009, Mid 2011, Mid 2012, Mid 2013, Mid 2017); MacBook Pro
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Mini DisplayPort...
£27.55
