Apple Pencil
Apple Pencil
£89.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Device Type: Apple Pencil
  • Type: Stylus
  • Device Screen Size: [N/A]
  • Colour: [N/A]
  • Stock Status: In Stock,
    Used stock also available below
Product codes
Bundle deals (2)
JUICE 2M LIGHTNING CABLE
= £98.98
Save £8.00
= £98.98
Save £8.00
Apple Pencil expands the power of iPad and opens up new creative possibilities. It's sensitive to pressure and tilt so you can easily vary line weight, create subtle shading, and produce a wide range of artistic effects - just like with a conventional pencil, but with pixel-perfect precision.
Compatible with:
  • iPad Air (3rd generation)
  • iPad mini (5th generation)
  • iPad (7th generation)
  • iPad (6th generation)
  • iPad Pro 12.9-inch (2nd generation)
  • iPad Pro 12.9-inch (1st generation)
  • iPad Pro 10.5-inch
  • iPad Pro 9.7-inch
Product Description Apple Pencil - stylus for tablet
Product Type Stylus
Intended For Tablet
Wireless Interface Bluetooth
Package Content Stylus, pen tip, lightning adapter
Designed For 10.2-inch iPad (7th generation); 10.5-inch iPad Air (3rd generation); 10.5-inch iPad Pro; 12.9-inch iPad Pro (1st generation, 2nd generation); 9.7-inch iPad (6th generation); 9.7-inch iPad Pro; iPad mini 5
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: BRJZ 042315
£47.47
product
Ref: BRJZ 042315
Accessories
Packaging
Functional
Software
Manuals
£47.47
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Pencil
£89.00
