We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The contrast your eyes see between brightness and darkness is very challenging to reproduce in a display, leading to the development of High Dynamic Range (HDR). With breakthrough backlighting technology, Pro Display XDR takes brightness, contrast, and color to the high level. Far beyond HDR, it's Extreme Dynamic Range (XDR).
Product Description | Apple Pro Display XDR Nano-texture glass - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | 6016 x 3384 at 60 Hz | Brightness | 1600 cd/m² | Contrast Ratio | 1000000:1 | Colour Support | 1.074 billion colours (10-bit) | Input Connectors | Thunderbolt 3 | Screen Coating | Matte | Voltage | AC 120/230 V (50 - 60 Hz) | Dimensions (WxDxH) - without stand | 71.8 cm x 2.7 cm x 41.2 cm | Weight | 7.48 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Panel Type | IPS |
Pixel Per Inch | 218 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Aluminum enclosure, BFR/PVC-free, Mercury free, beryllium free, arsenic free, Retina display, fully laminated display, True Tone display, 10-bit Colour Depth, P3 Wide Color Gamut, Extreme Dynamic Range (XDR), dual ambient light sensor |
Dimensions (WxDxH) | 71.8 cm x 2.7 cm x 41.2 cm - without stand |
Weight | 7.48 kg |
Connectivity | |
Interfaces | Thunderbolt 3 / USB-C (power up to 95W) , 3 x USB-C |
Miscellaneous | |
Included Accessories | Cleaning cloth |
Cables Included | 1 x Thunderbolt 3 cable - 2 m |
Power | |
Input Voltage | AC 120/230 V (50 - 60 Hz) |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
