We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Every aspect of Pro Stand was designed with pros in mind. Height, tilt, rotation - it's completely adjustable, allowing your Pro Display XDR to fit seamlessly into any work environment.
Product Description | Apple Pro Stand - stand - for Monitor | Product Type | Stand - desktop | Dimensions (WxDxH) | 18 cm x 23.6 cm x 49.7 cm | Tilt | -5° to 20° | Adjustments | Height, tilt, rotation | Weight | 4.3 kg | Recommended Use | Monitor | Designed For | Pro Display XDR |
General | |
Width | 18 cm |
Depth | 23.6 cm |
Height | 49.7 cm |
Weight | 4.3 kg |
AV Furniture | |
Type | Stand |
Placing / Mounting | Desktop |
Tilt | -5° to 20° |
Compatibility Information | |
Designed For | Apple Pro Display XDR |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
