We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Apple Studio Display combines state-of-the-art digital imaging technology with advanced software-based features unique to Apple. The result is a high-performance flat panel display that's ideal for anyone who spends a lot of time manipulating text, graphics, and other media on-screen. Whether you're a multimedia content creator, a designer, a writer, an educator, or an accountant, the Apple Studio Display can make your job look a lot better to you-and vice versa. The TFT active-matrix LCD technology used by the Apple Studio Display enables it to offer outstanding brightness, contrast ratio, and sharpness-for optimal viewing. It also provides an impressively wide viewing angle, as well as eliminating screen flicker. And the Apple Studio Display offers all this performance in a product that's a fraction the size of a traditional computer monitor.
Probably the most distinguishing feature of this display, though, is the advantage it takes of Apple's outstanding hardware/software integration. In the case of the Apple Studio Display, this enables an unmatched combination of "smart features" and superior software controls-adding up to an extraordinarily flexible, responsive device with which to view your work. In fact, the Apple Studio Display can make that eight-plus hours per day you spend in front of your computer significantly more productive - and surprisingly more pleasant. If you deal primarily with graphics, you'll be glad to know that the Apple Studio Display requires no special graphics adapter to work seamlessly with your computer. If you deal more with multimedia, you'll appreciate its built-in connectors for composite and S-video as well as audio input. And if what you deal with most frequently is a combination, you'll find the display's ability to shift instantly between graphics and video modes invaluable. The Apple Studio Display-when you look at all its high-performance capabilities, you'll really like what you see.
Product Description | Apple Studio Display Standard glass - LCD monitor - 5K - 27" - with tilt-adjustable stand | Device Type | LCD monitor - 27" | Energy Class | Class E | Features | 12 megapixel camera, 6 speakers, 3 microphone beam forming array, USB PD 96 Watt | Native Resolution | 5K 5120 x 2880 | Brightness | 600 cd/m² | Colour Support | 1 billion colours | Input Connectors | Thunderbolt 3 | Audio Input | 3-microphone array | Built-in Webcam | 12 Megapixel (ultra wide) | Display Position Adjustments | Tilt | Voltage | AC 100-240 V (50/60 Hz) | Dimensions (WxDxH) | 62.3 cm x 16.8 cm x 47.8 cm | Weight | 6.3 kg | Localisation | English / United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Display Type | LCD monitor |
Diagonal Size | 27" |
Built-in Devices | 12 megapixel camera, 6 speakers, 3 microphone beam forming array |
USB Power Delivery | 96 Watt |
Pixel Per Inch | 218 |
Features | Retina display, P3 Wide Color Gamut, True Tone technology, standard glass, Dolby Atmos |
Weight | 6.3 kg |
Built-in Webcam | |
Sensor Resolution | 12 Megapixel (ultra wide) |
Features | 122° field of view, F 2.4 lens aperture, Center Stage |
Audio Input | |
Type | 3-microphone array |
Audio | |
Type | Speakers with subwoofer - stereo with subwoofer |
Connectivity | |
Interfaces | Thunderbolt 3 / USB-C (power up to 96W) , 3 x USB-C |
Mechanical | |
Tilt Angle | -5/+25 |
Miscellaneous | |
Features | Spatial Audio, A13 Bionic chip |
Cables Included | 1 x Thunderbolt cable - 1 m |
Power | |
Input Voltage | AC 100-240 V (50/60 Hz) |
Power Consumption SDR (On mode) | 21.2 kWh/1000h |
Software / System Requirements | |
Included Software | Siri |
OS Required | Apple macOS Monterey 12.3 or later, Apple iPadOS 15.4 or later |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year , Technical support - phone consulting - 90 days |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
