Apple Studio Display - 27" 5120x2880 Tilt-Adjustable Stand
£1,457.36
Delivery:
Notify me
Key features
  • See what you can do
  • Sensational camera and audio
  • Six speakers, cinematic sound
  • Hear, there, and everywhere
  • Take charge of your studio
  • Stands, and delivers
Product codes
The Apple Studio Display combines state-of-the-art digital imaging technology with advanced software-based features unique to Apple. The result is a high-performance flat panel display that's ideal for anyone who spends a lot of time manipulating text, graphics, and other media on-screen. Whether you're a multimedia content creator, a designer, a writer, an educator, or an accountant, the Apple Studio Display can make your job look a lot better to you-and vice versa. The TFT active-matrix LCD technology used by the Apple Studio Display enables it to offer outstanding brightness, contrast ratio, and sharpness-for optimal viewing. It also provides an impressively wide viewing angle, as well as eliminating screen flicker. And the Apple Studio Display offers all this performance in a product that's a fraction the size of a traditional computer monitor.
Probably the most distinguishing feature of this display, though, is the advantage it takes of Apple's outstanding hardware/software integration. In the case of the Apple Studio Display, this enables an unmatched combination of "smart features" and superior software controls-adding up to an extraordinarily flexible, responsive device with which to view your work. In fact, the Apple Studio Display can make that eight-plus hours per day you spend in front of your computer significantly more productive - and surprisingly more pleasant. If you deal primarily with graphics, you'll be glad to know that the Apple Studio Display requires no special graphics adapter to work seamlessly with your computer. If you deal more with multimedia, you'll appreciate its built-in connectors for composite and S-video as well as audio input. And if what you deal with most frequently is a combination, you'll find the display's ability to shift instantly between graphics and video modes invaluable. The Apple Studio Display-when you look at all its high-performance capabilities, you'll really like what you see.
Product Description Apple Studio Display Standard glass - LCD monitor - 5K - 27" - with tilt-adjustable stand
Device Type LCD monitor - 27"
Energy Class Class E
Features 12 megapixel camera, 6 speakers, 3 microphone beam forming array, USB PD 96 Watt
Native Resolution 5K 5120 x 2880
Brightness 600 cd/m²
Colour Support 1 billion colours
Input Connectors Thunderbolt 3
Audio Input 3-microphone array
Built-in Webcam 12 Megapixel (ultra wide)
Display Position Adjustments Tilt
Voltage AC 100-240 V (50/60 Hz)
Dimensions (WxDxH) 62.3 cm x 16.8 cm x 47.8 cm
Weight 6.3 kg
Localisation English / United Kingdom
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£1,457.36
Notify me
