Apple Thunderbolt Cable 2m
£56.79
Delivery:
Standard: 1-3 working days
  • Length: 2m
  • Colour: White
  • Stock Status: In Stock
Product codes
With Thunderbolt, you get superfast data transfer speeds and huge expansion capabilities. It features two 10-Gbps data channels per port, which means data transfer is up to twice as fast as USB 3 and up to 12 times faster than FireWire 800.
Use the Apple Thunderbolt Cable to connect your Thunderbolt-equipped peripherals to your iMac, Mac mini, MacBook Pro, or MacBook Air. The cable can also be used for target disk mode between two Mac computers that support Thunderbolt, or to use an iMac as a display for a MacBook Pro equipped with Thunderbolt.
Product Description Apple Thunderbolt cable - 2 m
Type Thunderbolt cable
Length 2 m
Connector Mini DisplayPort - male
Connector (Second End) Mini DisplayPort - male
Colour White
Designed For iMac (Late 2012, Late 2013, Late 2014, Late 2015, Mid 2011, Mid 2014, Mid 2015); Mac mini (Late 2012, Late 2014, Mid 2011); MacBook Air (Early 2014, Early 2015, Mid 2011, Mid 2012, Mid 2013, Mid 2014, Mid 2017); MacBook Pro
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Thunderbolt Cabl...
£56.79
