Apple Thunderbolt to Gigabit Ethernet Adapter
£29.28
Delivery:
Standard: 1-3 working days
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Form Factor: External
  • Compatibility: Mac
  • Type: Network adapter
Product codes
Bundle deals (2)
JUICE 2M LIGHTNING CABLE
= £39.26
Save £8.00
= £39.26
Save £8.00
The Apple Thunderbolt to Gigabit Ethernet Adapter lets you easily connect to a high-performance Gigabit Ethernet network. Small and compact, it connects to the Thunderbolt port on your Mac computer and provides an RJ-45 port that supports 10/100/1000BASE-T networks.
Compatibility
  • Mac: OS X v10.7.4 or later
  • Thunderbolt-equipped Mac computer
What's in the Box?
  • Apple Thunderbolt to Gigabit Ethernet Adapter with built-in Thunderbolt cable
Product Description Apple Thunderbolt to Gigabit Ethernet Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type Thunderbolt
Ports Gigabit Ethernet
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1 Gbps
System Requirements Apple MacOS X 10.7.4 or later
Designed For iMac; Mac mini; MacBook Air; MacBook Pro
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Thunderbolt to G...
£29.28
