This 2-meter charge cable features a magnetic MagSafe 3 connector that helps guide the plug to the power port of your MacBook Pro. Pair it with a compatible USB-C power adapter to conveniently charge your MacBook Pro from a power point and take advantage of fast-charging capabilities. The magnetic connection is strong enough to resist most unintended disconnects, but if someone trips on the cable, it releases so your MacBook Pro stays put. An LED turns amber when the battery is charging and green when it's fully charged. Made with a woven design for long-lasting durability.
Product Description | Apple - power cable - 24 pin USB-C to MagSafe 3 - 2 m | Type | Power cable | Length | 2 m | Connector | 24 pin USB-C - male | Connector (Second End) | Apple MagSafe 3 - male | Manufacturer Warranty | 1-year warranty | Designed For | MacBook Air (Mid 2022); MacBook Pro (Late 2021) |
General | |
Length | 2 m |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | 1-year warranty |
Compatibility Information | |
Designed For | Apple MacBook Air (Mid 2022) , Apple MacBook Pro (Late 2021) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
