Apple USB ethernet adaptor
£29.28
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easily connect your MacBook Air computer to an Ethernet network with the Apple USB Ethernet Adapter
  • Small and light, it connects to the USB 2.0 port of your MacBook Air and provides an RJ-45 connector that supports 10/100BASE-T performance
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet
  • Form Factor: External
  • Compatibility: Mac
  • Type: Network adapter
Product codes
Bundle deals (2)
JUICE 2M LIGHTNING CABLE
= £39.26
Save £8.00
= £39.26
Save £8.00
The Apple USB Ethernet Adapter is a simple, one-piece external adapter that plugs into the USB 2.0 port of your MacBook Air to provide 10/100BASE-T performance. Simply plug your Ethernet cable into the RJ-45 connector - no external power is required. It's small, light, easy to install, and even easier to use.
Product Description Apple USB Ethernet Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Ports 10/100 Ethernet
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX
Data Link Protocol 10Mb LAN, 100Mb LAN
Data Transfer Rate 100 Mbps
Compliant Standards USB 2.0
System Requirements Apple MacOS X 10.4.8 or later
Designed For MacBook Air
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple USB ethernet ada...
£29.28
