Compact and convenient, the Apple USB SuperDrive connects to your MacBook Pro with Retina display, MacBook Air, or Mac mini with a single USB cable and fits easily into a travel bag. It lets you install software and play and burn both CDs and DVDs, including double-layer DVDs.
Product Description | Apple USB SuperDrive - DVD±RW (±R DL) drive - USB 2.0 - external | Device Type | DVD±RW (±R DL) drive - external | Interface | USB 2.0 | Dimensions (WxDxH) | 13.9 cm x 13.9 cm x 1.7 cm | Weight | 335 g | Optical Storage | DVD±RW (±R DL) | Read Speed | 24x (CD) / 8x (DVD) | Write Speed | 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) | CD / DVD Rewrite Speed | 16x (CD) / 6x (DVD-RW) / 8x (DVD+RW) | Media Load Type | Slot-load | Designed For | iMac; iMac Pro; Mac mini; Mac Pro; MacBook; MacBook Air; MacBook Pro with Retina display |
General | |
Width | 13.9 cm |
Depth | 13.9 cm |
Height | 1.7 cm |
Weight | 335 g |
Optical Storage | |
Type | DVD±RW (±R DL) |
Supported Media Formats | CD-ROM |
Supported Media Types | CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL |
Expansion / Connectivity | |
Interfaces | 1 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Cables Included | 1 x USB cable - integrated |
Compatibility Information | |
Designed For | Apple iMac , Apple iMac Pro , Apple Mac mini , Apple Mac Pro , Apple MacBook , Apple MacBook Air , Apple MacBook Pro with Retina display |
