Apple Watch Series 4 GPS, 44mm Gold Aluminium Case...
Apple Watch Series 4 GPS, 44mm Gold Aluminium Case with Pink Sand Sport Band
£369.00
Colours:
2 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Not just evolved, transformed
  • Part guardian, part guru
  • Workouts that work harder
  • Made to motivate
  • Device Type: Apple Watch
  • Type: SmartWatch
  • Stock Status: In Stock, Used Stock
Product codes
All new. For a better you.
Introducing Apple Watch Series 4. Fundamentally redesigned and re-engineered to help you stay even more active, healthy and connected.
Product Description Apple Watch Series 4 (GPS) - gold aluminium - smart watch with sport band - pink sand - 16 GB
Product Type Smart watch
Operating System Watch OS 5
Storage 16 GB
Connectivity Wi-Fi, Bluetooth
Processor Apple S4
Supported Host Device OS iOS
Display LTPO OLED 368 x 448 pixels
Input Force Touch
Tracking Data Distance, time, calories burned, activity, heart rate, steps taken, UV index, Air Quality index
Band Pink sand - sport band - fluoroelastomer - 140-210 mm
Features Heart rate sensor, navigation, music remote handling, microphone, EKG accurate heart rate, calendar notification, SMS notification, Email notification, listening to music, Retina Display technology, call alerts, automatic exercise recognition, Fall detection, Emergency SOS
Battery Run Time Up to 18 hours
Case Size 44 mm
Case Material Anodised aluminium
Dimensions (WxDxH) 38 mm x 10.7 mm x 44 mm
Weight 36.7 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: DSN6 040939
£350.72
product
Ref: DSN6 040939
Accessories
Packaging
Functional
Software
Manuals
£350.72
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Apple Watch Series 4 G...
£369.00
