With the Wireless Charging Case, charging your earbuds is simple. The LED indicator on the front of the case lets you know that your earbuds are charging. And when you're away from a charging mat, you can use the Lightning port to charge.
Product Description | Apple Wireless Charging Case charging case | Product Type | Charging case | Dimensions (WxDxH) | 4.43 cm x 2.13 cm x 5.35 cm | Weight | 40 g | Wireless Charging | Yes | Wireless Charging Standards | Qi | Designed For | AirPods (1st generation, 2nd generation) |
General | |
Designed For | Headphones |
Width | 4.43 cm |
Depth | 2.13 cm |
Height | 5.35 cm |
Weight | 40 g |
Power Device | |
Input Connectors | Apple Lightning |
Input Connectors Qty | 1 |
Features | LED indicator |
Compatibility Information | |
Designed For | Apple AirPods (1st generation, 2nd generation) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
