Arlo Essential Spotlight Camera - White
FREE DELIVERY
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Weather-resistant security
  • See in color, even at night
  • Quickly install
  • Deter intruders with built-in siren
  • Get alerts when motion is detected
  • Type: Home security and monitoring system, Outdoor Camera, Motion sensor / camera
  • Compatible With: Alexa, Google Assistant
Product codes
Bundle deals (2)
GOOGLE NEST HUB SMART DISPLAY
= £168.00
Save £5.00
NEST MINI SMART SPEAKER
= £158.00
Cover the basics with our straightforward wireless security camera.
Home security you can control from your smartphone. 100% wire-free and weather resistant, install in minutes for no-fuss protection.
6 month battery life
Wire-free, no cords or wiring hassles
Capture clear details in full high definition
Record video in 1080p, and see more of the picture with a 130° viewing angle.
Weather Resistant
Withstands heat, cold, rain or sun
Motion detection alerts
Take quick action and view live video, sound the siren, or call a friend directly from your phone.
See in colour, even at night
Ward off intruders and view unique details in colour with the integrated spotlight.
Simple installation
Set up your camera in a few easy steps thanks to its 100% wireless design. Connect directly to wifi - no base station required.
2-way audio
Hear and speak to visitors in real time with high quality audio via the Arlo app or using your smart assistant.
Set the siren to sound automatically during an event or trigger it remotely from the app.
Connect and control with your favourite smart assistant
Works with Amazon Alexa, Google Assistant and IFTTT.
Product Description Arlo Essential - network surveillance camera
Device Type Network surveillance camera - fixed - outdoor, indoor - weatherproof
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Camera Mount Type Wall mount
Dimensions (WxDxH) 5.2 cm x 7.84 cm x 8.9 cm
Weight 331 g
Colour White
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type CMOS
Interfaces Wi-Fi
Intelligent Assistant Google Assistant, Alexa
Features E-mail alerts, echo reduction, built-in siren, noise-cancellation, built-in spotlight, 110-degree motion detection angle
Manufacturer Warranty 1-year warranty
Environmental Parameters (operating) -20 °C - 45 °C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£129.00
