Our most powerful floodlight camera
The first 100% wire-free floodlight camera illuminates the most vulnerable parts of your property. A motion-activated light more powerful than a car headlight deters intruders before they even get close to your property. While 2K video captures all the important details for the best possible protection.
Wire-Free Security Installed in Minutes.
Easily mounts in multiple locations for protection from every angle.
Never be left in the dark
Light up your property with 2000-3000 lumens.
Color Night Vision
See video in full color or traditional black and white.
2K HDR
Zoom in on objects and capture clearer details and colors.
160° Viewing Angle
Keep an eye on what matters with a wide 160° diagonal field of view.
2-Way Audio
Hear and speak to visitors clearly with superior audio quality.
Built-in Smart Siren
Trigger your siren automatically, or manually from the Arlo app.
Weather-resistant design
Built to withstand heat, cold, rain or sun.
Custom control
Easily adjust brightness, video, and audio settings to your preference.
Rechargeable battery
Go wire-free with a convenient and long-lasting battery.
Multiple power options
Keep your floodlight camera charged all day with an optional Solar Panel or Outdoor Charging Cable (sold separately).
3-month Arlo Smart trial included
Personalized notifications keep you informed of events that matter so you can take quick action—from phoning a friend to sound an alarm, or calling emergency services.
What's included:
(1) Arlo Pro 3 Floodlight Camera
(1) XL Rechargeable Battery
(1) Power Adapter
(1) Micro-USB Cable
(1) Wall Plate and Screw Kit
(1) Quick Start Guide
(1) Video Monitoring Decal
Product Description | Arlo Pro 3 Floodlight Camera - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: two-way audio capability, built-in microphone | Camera Mount Type | Wall mount | Dimensions (WxDxH) | 21.852 cm x 19.05 cm x 7.793 cm | Weight | 650 g | Colour | Black | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 2560 x 1440 | Video Modes | 720p, 1080p, 2K | Optical Sensor Type | 1/3" - 4 MP | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Cables Included | 1 - micro-USB cable - external | Features | High Dynamic Range (HDR), built-in siren, Colour Night Vision, built-in spotlight | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 45 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: two-way audio capability, built-in microphone |
Width | 21.852 cm |
Depth | 19.05 cm |
Height | 7.793 cm |
Weight | 650 g |
Localisation | Europe |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Digital Video Format | H.264, H.265 |
Max Digital Video Resolution | 2560 x 1440 |
Digital Zoom | 12 |
Image Sensor | |
Type | 4 MP 1/3" |
Lens Construction | |
Horizontal Field of View (degree) | 160 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Wall mount kit, screw kit, rechargeable battery, video monitoring decal |
Cables Included | 1 x micro-USB cable - external |
Colour | Black |
Power | |
Power Device | Power adapter - external AC 100 - 240 V |
Battery | 1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight (Shipping) | |
Shipping Width | 24.5 cm |
Shipping Depth | 19.8 cm |
Shipping Height | 13.4 cm |
Shipping Weight | 1.362 kg |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
