Rest easy knowing your loved ones are safe and secure, whether you're home or away. Arlo Pro 4 sets up in minutes and helps you see a clearer picture of home, day and night.
Built-in Siren
Trigger the siren from the Arlo app or have it sound automatically when motion is detected
Wire-free & Weather Resistant
100% wire-free and weather resistant
2K Video with HDR
12x zoom with 2K HDR video lets you capture important details with clarity.
Integrated Spotlight
A powerful spotlight lets you see important details even at night
Crystal Clear Audio
Hear and speak to anyone in your home from your smartphone, through the built-in speaker and microphone.
160° Field of View
Focus on the most vulnerable parts of your property with wide angle 160-degree viewing.
Colour Night Vision
Capture important information, even at night with vivid colour night vision.
Connect Direct to WIFI
No base station required - simply connect to your 2.4Ghz wifi network for the camera to work.
What's included:
4x Arlo Pro 4 Spotlight Camera
1x Wall Mount
4x Rechargeable Battery
1x Magnetic Charging Cable
4x Wall Mount Screw Kit
1x Quick Start Guide
1x Arlo Monitoring Decal
Product Description | Arlo Pro 4 - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Packaged Quantity | 4 (specifications are for single item) | Audio | Yes: two-way audio capability, built-in microphone | Camera Mount Type | Wall mount | Dimensions (WxDxH) | 8.9 cm x 5.2 cm x 7.84 cm | Weight | 316 g | Colour | White | Connectivity Technology | Wired, wireless | Camera | Colour - Day&Night | Max Resolution | 2560 x 1440 | Motion Detection | Yes | Video Modes | 720p, 1080p, 2K | Optical Sensor Type | 1/3" - 4 MP | Interfaces | USB 2.0 IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Wi-Fi | Cables Included | Magnetic charging cable | Voltage | AC 100-240 V, DC 5 V | Features | Auto tracking, High Dynamic Range (HDR), 160° field of view, built-in spotlight, 130-degree motion detection angle | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 45 °C |
