We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Arlo Ultra
Cutting edge protection for what matters most
Crystal clear 4K image quality
While typical security camera footage is infamous for its low fidelity, the Arlo Ultra camera and SmartHub deliver high performance 4K HDR that ensures cutting-edge image quality.
Advanced dewarping
Get a more complete picture of your property with a 180-degree diagonal field of view—and without the typical fisheye distortion.
4K video with HDR
See more details in a wide range of light conditions, from bright highlights to dark shadows.
Close-up zoom
High resolution 4K video reveals key image details, including words, logos and license plates.
A spotlight that never sleeps
Ward off unwelcome guests with Arlo Ultra's powerfully bright, motion-activated spotlight.
Enhanced color night vision
The integrated spotlight allows you to see video in color rather than traditional black and white.
Auto-zoom and tracking
Arlo Ultra intelligently adjusts to movement, focusing its frame on what matters.
Keep watch without wires
Wire-free and WiFi enabled, Arlo Ultra camera goes anywhere you need to protect your home.
On guard rain or shine
Arlo Ultra camera is weather-resistant so it works indoors or out in rain, sleet or snow.
It's your eyes. And ears.
Listen and speak with anyone in range of your Arlo Ultra with clear, full 2-way audio.
A smarter home siren
Set your siren to sound automatically, or trigger it from your phone upon receiving an alert.
Pristine audio adds powerful security
Arlo Ultra features dual, noise-cancelling microphones that reduces distracting background noises like wind, rain and street activity, providing you clearer distortion-free sound.
3 Camera System - What's included:
3 Cameras + battery
1 Power Adapter
1 Magnetic Charge Cable
1 Ethernet Cable
2 Magnetic Mount
1 Quarter Twenty Mount
3 Wall Mount Screw Kit
1 Quarter Twenty Screw
1 Quick Start Guide
1 Decal
1 Ultra SmartHub (VMB5000)
Product Description | Arlo Ultra 4K UHD Wire-Free Security Camera System - gateway + camera(s) - wireless (802.11b, 802.11g, 802.11n, 802.11ac, Bluetooth 4.2) | System | Gateway + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 | Camera | 3 cameras - outdoor - night vision | Intelligent Assistant | Siri, Google Assistant, Alexa | Colour | White | Localisation | Europe | Manufacturer Warranty | 1 year |
General | |
System | Gateway + camera(s) - wireless |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Features | microSD card slot, motion detection, 4K Ultra HD video, High Dynamic Range (HDR), two-way audio support, spotlight, 12x digital zoom |
Package Content | Power adapter, mounting screws, magnetic charging cable, 3 camera wall mounts, video monitoring decal, SmartHub, 3 camera batteries |
Cables Included | Network cable - 1 pcs. |
Colour | White |
Warranty | 1 year |
Security DVR | |
Compression Format | H.264, H.265 |
Cameras | |
Quantity | 3 cameras |
Camera Type | Outdoor |
Sensor | 1/2" - 8 Megapixel |
Field of View | 180° |
Night Vision | Yes |
White Balance | Auto |
Gain Control | Auto |
Voltage | DC 5 V |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 60 °C |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Dimensions & Weight | |
Details | Camera: 5.2 cm x 7.84 cm x 8.9 cm - 330 g , Gateway: 14 cm x 5.24 cm x 15.3 cm - 300 g |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
