With an Arlo system, you'll have everything you need to get started. Just connect the base station to your Wi-Fi router, sync your cameras, fire up the free Arlo app, and you’re done in minutes. Make sure to upgrade your service plan and add more cameras to make the most out of your system.
Product Description | Arlo VMS3430 - video server + camera(s) - wireless | System | Video server + camera(s) - wireless - 2.4 GHz | Camera | 4 cameras - outdoor - night vision |
General | |
System | Video server + camera(s) - wireless |
Wireless Frequency Band | 2.4 GHz |
Package Content | 4 cameras, power adapter, 4 magnetic mounts, 4 mounting screws, window decal, 16 lithium batteries (CR123) |
Cables Included | Network cable - 1 pcs. |
Security DVR | |
Compression Format | H.264 |
Video Server | |
RAM | 64 MB |
Flash Memory | 16 MB |
Features | LED indicator |
Cameras | |
Quantity | 4 cameras |
Camera Type | Outdoor |
Sensor | CMOS |
Field of View | 130° |
Night Vision | Yes |
Infrared Distance | 7.5 m |
White Balance | Auto |
Min Operating Temperature | -10 °C |
Max Operating Temperature | 50 °C |
Compliant Standards | IP65 |
Connections | |
Network Port | 10/100Base-T |
Dimensions & Weight | |
Details | Video server: 21.6 cm x 16.5 cm x 5.72 cm - 113 g , Camera: 4.1 cm x 7.1 cm x 6.4 cm - 113 g |
