ASRock Z270 Extreme4 LGA1151 Intel Z270 DDR4 ATX
Key features
  • Intel LAN
  • Advanced memory ready
  • User-friendly UEFI and EZ mode
  • Water pump header
  • Triple monitor
  • 3 graphics outputs
  • Dual USB 3.1 (Type A + Type C)
Product codes
Armor Your VR Machine
Prepare yourself well to enjoy the impressive world of Virtual Reality. Before that, you have to make sure everything is qualified, including hardware, software and drivers. Motherboard is the key to connect every critical components and ASRock’s VR Ready motherboards are definitely the one you’re looking for. The premium qualify is assured by rigorous testing during development. The sturdy components and rock-slid performance makes you completely immersive in the VR scenario. Users can be assured to experience VR enjoyments without any compatibility problems.
AURA RGB LED
Build your own colorful lighting system! AURA RGB LED and header allows users to connect LED strip and create their unique PC style easily.
Purity Sound 4
It's time to enjoy the most purified audio performance with ultra high definition. Purity Sound4 is a combination of several hardware, software audio solutions. 7.1 CH HD audio with the latest Realtek ALC1220 audio codec, individual PCB layers for R/L audio channel, 120dB SNR DAC and other technologies to deliver the crispest sound effects.
  • 120dB SNR DAC
  • AURA RGB LED
  • Gold Audio connector
  • TI® NE5532 Premium Headset Amplifier
  • Individual PCB Layers for R/L Audio Channel
  • Impedance Sensing on Front Out port
  • PCB Isolate Shielding
  • Pure Power-In
  • Nichicon Fine Gold Series Audio Caps
  • Gold Audio Jacks
Dual Ultra M.2 For SSD
Two of the world’s fastest PCIe Gen3 x4 Ultra M.2 slots that deliver up to 32Gb/s transfer speed, it also supports SATA3 6Gb/s M.2 modules.
Product Description ASRock Z270 Extreme4 - motherboard - ATX - LGA1151 Socket - Z270
Product Type Motherboard - ATX
Chipset Type Intel Z270 Express
Processor Socket LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports 8 x SATA-600 (RAID), 2 x Ultra M.2
USB / FireWire Ports USB 3.0, USB 3.1, USB-C
Max Allocated RAM Size 1024 MB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
ASRock Z270 Extreme4 L...
