Asus AMD Radeon R5 230 625MHz 1GB DDR3 PCI-E VGA DVI HDMI
£41.49
Delivery:
Standard: 1-3 working days
Key features
  • Silent passive cooling means true 0 dB - perfect for quiet home theater PCs and multimedia centers
  • Lowers graphics card EMI by 66% for more stable operation, clearer display, and safer computing
  • Low profile graphics cards for HTPC and multimedia PCs support smooth 1280 x 1024 gaming and Blu-ray 3D
  • GPU tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface
  • GPU tweak streaming tool allows you to share on-screen action in real-time, add scrolling text, pictures, and webcam images to the streaming window easily
Product codes
R5 230 is the fantastic graphics card from ASUS. Engineered with a highly-efficient 0 dB thermal design, it dissipates heat in complete silence - making R5 230 the perfect choice for your slim line home-theater PC (HTPC) build. Advanced EMI shielding reduces electromagnetic interference by up to 66% for a stable signal, pin-sharp images and safer and healthier computing.
Exclusive ASUS-designed heatsinks with large surface areas effectively cool graphics cards passively so absolutely no sound is produced while running - perfect for high definition and silent home theater PCs and multimedia centers.
Product Description ASUS R5230-SL-1GD3-L - graphics card - Radeon R5 230 - 1 GB
Device Type Graphics card - low profile
Bus Type PCI Express 2.1 x16
Graphics Engine AMD Radeon R5 230
Memory 1 GB DDR3
Core Clock 625 MHz
Effective Memory Clock 1.2 GHz
Memory Interface 64-bit
Max Resolution 2560 x 1600
Interfaces DVI-D (dual link) , HDMI , VGA
API Supported DirectX 11
Fanless Yes
Dimensions (WxDxH) 16.764 cm x 6.86 cm
Microsoft Certification Compatible with Windows 7
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus AMD Radeon R5 230...
£41.49
