Asus B1MR DLP WXGA Wireless Mobile Projector with Bag
Key features
  • Incredibly sharp visuals with 900-lumen light output and WXGA 1280 x 800 resolution
  • Wireless Projection Ready lets you wirelessly connect and stream presentations
  • Short throw projection of 51-inch from just 1 meter from the screen
  • Quick setup time with instant on/off capability, auto keystone correction, and two-level kickstand design
  • PC-free multi-format compatibility with built-in HDMI, SD card reader, USB plus dual ASUS SonicMaster audio speakers
Product codes
The ASUS B1MR Ultra-bright Wireless LED Projector delivers incredibly bright, sharp visuals with native WXGA 1280 x 800 resolution, 900 lumens light output, and a 100% NTSC color scale to project precise, detailed color images. The B1MR features a mercury-free Eco-LED light source with a 30,000-hour lifespan to cut down on maintenance and bulb-replacement costs.
Product Description ASUS B1MR - DLP projector - short-throw - portable - 3D
Device Type DLP projector
3D Capable Yes
Colour Black
Brightness 900 lumens
Contrast Ratio 10000:1
Resolution WXGA (1280 x 800)
Native Aspect Ratio 16:10
Colour Support 1.07 billion colours
Lens Short-throw fixed lens
Bulb type RGB LED
Bulb life cycle Up to 30000 hour(s)
Video Input RGB, composite video - MPEG-4, AVI, WMV, MOV, MPG, MKV
Supported Memory Cards SD Memory Card
Speakers Speaker(s) - integrated
Power Consumption Operational 85 Watt
Dimensions (WxDxH) 17.5 cm x 13.9 cm x 4.45 cm
Weight 900 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus B1MR DLP WXGA Wir...
