Asus BE209QLB 19.5" 1440 x 900 5ms DVI-D VGA Monitor
£135.44
Delivery:
Key features
  • In-plane switching panel with wide viewing angles and LED backlight for quality visuals
  • Extensive connectivity with DisplayPort, DVI-D, D-sub, audio in, earphone jack plus USB 2.0 ports for the most flexibility
  • Advanced eye care feature with low blue light & flicker free technology
  • Ergonomic design with tilt, swivel, pivot and height adjustments for a comfortable viewing experience
Product codes
BE209QLB LCD monitor features a 1440 x 900 resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
BE209QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, audio in, earphone jack, and two USB 2.0 ports.
ASUS BE209QLB - LED monitor - 19.45"
LED-backlit LCD monitor - 19.45"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
1440 x 900
Pixel Pitch
0.2907 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
45.7 cm x 21.1 cm x 34.6 cm
4.8 kg
Environmental Standards
ENERGY STAR Qualified
UL, TUV, TUV GS, VCCI, BSMI, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, WEEE, PSE Mark, MEPS, ErP Ready, UkrSEPRO, TCO Displays 6.0, RCM, ISO9241-307, Ukraine EMC DoC, TUV Rheinland Low Blue Light Certification
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus BE209QLB 19.5" 14...
£135.44
