Asus BE229QLB 21.5" 1920 x 1080 5ms VGA DVI Monitor
£167.54
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Vivid, lifelike visuals with 178° wide-view angles
  • Extensive connectivity
  • Great viewing comfort with Eye Care technology and ergonomic design for everyday computing
  • ASUS Flicker Free technology
  • ASUS Low Blue Light technology - Blue Light Filter
  • Versatile comfort with ergonomic stand design
  • Bundled with the MiniPC kit
  • Diagonal Size: 21.5in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
BE229QLB LCD monitor features a Full HD(1920x1080) resolution with LED-backlit IPS panel and a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction.
BE229QLB LCD monitor features a host of connectivity options that include DisplayPort, DVI-D, D-sub, Audio in, Earphone jack, and two USB 2.0 ports.
Say goodbye to tired, strained eyes. ASUS BE229QLB features ASUS Flicker-free and Low Blue Light technologies to reduce instances of eyestrain and other damaging effects when spending long, countless hours in front of a display.
ASUS Flicker-Free technology by using Smart Dynamic Backlight Adjustment avoids low brightness level and high speed LED backlight flashing, clears out the distractive flicker, and brings comfort viewing experience to avoid Computer Vision Syndrome.
Product Description ASUS BE229QLB - LED monitor - Full HD (1080p) - 21.5"
Device Type LED-backlit LCD monitor - 21.5"
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.248 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 100000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare
Colour Black
Dimensions (WxDxH) - with stand 51.4 cm x 21.1 cm x 34.7 cm
Weight 5.7 kg
Microsoft Certification Compatible with Windows 7
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards UL, TUV GS, VCCI, BSMI, cUL, WHQL, CB, TUV Ergo, FCC, RoHS, WEEE, MEPS, ErP Ready, UkrSEPRO, RCM, ISO9241-307, TUV Rheinland Low Blue Light Certification
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Asus BE229QLB 21.5" 19...
£167.54
