The ASUS Chromebook C213 is the ideal education computer for every school IT manager, student, and teacher. With its classroom ruggedness, the ASUS Chromebook C213 is developed to meet the daily rigors and intense usage by students both inside and outside of the classroom. Beyond its rugged construction, the ASUS Chromebook C213 is also designed for easy maintenance to minimize downtime. The result is a Chromebook, which is designed for maximum usage, creating more learning opportunities for students.
Military grade reliability & durability to withstand every situation in school
Every C213 is put through a rigorous chain of reliability tests to ensure it functions without disruption. These tests affirm that the C213’s solid and sturdy construction can withstand the punishing demands of modern day education.
No disruption from accidental drops
Dropping the notebook in school is a major problem as components can be damaged and affecting its function. Well, not anymore as the C213’s best-in-class drop test from 120cm height ensures the critical components are protected.
Reduces the impact from any knocks and drops
All 4 exterior edges and corners of the C213 are protected by rubber wrapped protective guard, using reinforced nano-molding technology, offering maximum security for critical components.
Clever features making typing a bliss every day
A spill-resistant keyboard is a must for the classroom where accidental spilling of liquid is not uncommon. A 2mm key travel also allows for more accurate typing.
Convenient every time and every day
The versatility of 4 viewing modes, from a laptop, tablet, stand to tent mode, provides the best studying angle for students in a classroom or outdoors. The 360-degree flip mechanism also allows the C213 to be opened to any desired angle to fit the required situation.
More interaction & more responsive learning
Touch learning mirrors the lifestyle habit of students as they live in a world of touch gadgets. This familiarity not only allows for easy usage of the C213 but also encourages a higher level of intuitive interaction.
Learning becomes more fun with video conference & photography
The ingenious dual camera function allows for video conference and photography, taking the learning experience to a whole new level of creativity and collaboration. Not forgetting the hours of fun the dual camera will bring, especially during field trips.
Product Description | ASUS Chromebook Flip C213NA BU0033 - 11.6" - Celeron N3350 - 4 GB RAM - 32 GB eMMC | Product Type | Chromebook - flip design | Operating System | Chrome OS | Processor | Intel Celeron N3350 / 1.1 GHz (2.4 GHz) / 2 MB Cache | Memory | 4 GB LPDDR3 (provided memory is soldered) | Storage | 32 GB - eMMC | Display | 11.6" LED backlight touchscreen 1600 x 900 / HD+ | Graphics | Intel HD Graphics 500 | Integrated Webcam | Yes | Networking | 802.11ac, Bluetooth 4.1 | Battery | 4-cell | Colour | Grey, dark grey | Dimensions (WxDxH) | 30.7 cm x 19.9 cm x 2.06 cm | Weight | 1.25 kg | Manufacturer Warranty | Limited warranty - 3 years - on-site |
Customer return - item has been used and shows signs of use.
Not in original packaging.
Ref: D2P6 041175 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
