ASUS Chromebox 3 features a powerful processor and DDR4 memory for faster, smoother and more energy-efficient performance. It gives you the ability to run your favorite mobile apps with the power of a mini PC.
Product Description | ASUS Chromebox 3 N006U - mini PC - Core i7 8550U - 16 GB - 256 GB | Type | Chromebox - mini PC | Processor | 1 x Intel Core i7 (8th Gen) 8550U (Quad-Core) | RAM | 16 GB (installed) / 16 GB (max) - DDR4 SDRAM | Hard Drive | 1 x SSD 256 GB - M.2 | Optical Storage | No optical drive | Card Reader | 3 in 1 | Graphics Controller | Intel UHD Graphics 620 | Networking | GigE, 802.11ac, Bluetooth 4.2 | OS Provided | Google Chrome OS | Dimensions (WxDxH) | 14.85 cm x 14.85 cm x 4 cm | Weight | 1 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Chromebox |
Product Form Factor | Mini PC |
Embedded Security | Trusted Platform Module (TPM) Security Chip |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8550U |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
RAM | |
Installed Size | 16 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 0 (empty) |
Configuration Features | 2 x 8 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 256 GB |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | 3 in 1 card reader |
Supported Flash Memory Cards | microSD, microSDHC, microSDXC |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 620 |
Video Interfaces | HDMI, DisplayPort |
Max Monitors Supported | 2 |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Interfaces | 2 x USB 3.1 Gen 1 (2 in front) (Battery Charging 1.2) , 1 x HDMI , 1 x headphones/microphone (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort/USB-C 3.1 Gen 1 , 3 x USB 3.1 Gen 1 |
Miscellaneous | |
Included Accessories | VESA mounting kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | Yes |
Compliant Standards | UL, VCCI, BSMI, CB, FCC, RCM |
Power | |
Device Type | Power adapter |
Power Provided | 90 Watt |
Operating System / Software | |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 14.85 cm |
Depth | 14.85 cm |
Height | 4 cm |
Weight | 1 kg |
Environmental Parameters | |
Sound Emission | 19.3 dB |
